My center LCD display's bulb went out and I'm looking to replace the bulb. Does anyone know where I can get the bulb ? BTw, the LCD works, its just not iluminated. I see whe forcing my eyes hardly to focus the digital speedo. The car is a 98 boxster.
AutohausAZ.com has them real cheap.
be VERY careful when you remove the dash pod. it has very sharp plastic posts on both sides that WILL gouge your dash. make sure you cover these posts and the surrounding dash area and carefully watch what you are doing. it only takes a second of the post resting on the dash to mark it up badly.
if you DO mark up the dash, use a hairdryer to heat the area up really good and try to massage the mark out with your thumb/fingers. repeat if necessary.
