Airbag light stays on after raplacing window regulator
If you left the key in the ignition with any airbag disconnected it will trigger the light. Only way to clear it is a trip to the dealer or find someone with the Durametric software.
oh no, thanks ...
Fred:
There are lots of RennTech members in your area with a Durametric. See if you can hook up with one of them to get the airbag light turned off. Also, post on PPBB.com for anyone in your area that can give you a hand the same way.
Don't go to the dealer to get the light turned off, it will take some of the satisfaction from having done the window regulator yourself away, if you can help it.
