P1124 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold
P1126 Oxygen Sensing Adaptation Area 1 (Cylinders 4 1 6) - Rich Threshold
These mean your car is running too lean and the DME can not make the mixture rich enough.
Potential causes:
- Intake air system leaking or exhaust leak (air leaks ahead of the oxygen sensors is a common cause of these faults).
- Fuel pressure too low.
- Volume supply of fuel pump too low.
- Fuel injectors fouled.
It is also possible that your MAF is giving errant readings. So, it would not hurt to clean your MAF or have the air flow tested.
