DIY front wheel bearing replacement 996 tt,c4,GT2
Now let me say that this job was quite straightfoward, BUT I would suggest that you have a bit of experience in bearing fittting as well as presswork or you may really mess things up in a big way. You also need a ball joint service puller set, and yes you need ALL the tools in the kit. I got mine from OTC/ msc industrial supply cat #78453842. You will also need a way to make some mandrels for pressing the bearings in and out. And a way to heat the carrier to around 150 degrees. Now for t
  • 3 months later...
  • 8 months later...
Hello, I have a 2002 996 Targa and get a very loud grinding noise coming from the fron the car when I turn left or right while giving it gas in turns, but when I turn through corners and do no give it gas their in no noise! Also if I accelerate hard from a standstill it also makes that same noise when turning. Do is this a sign of a fron wheel bearing being shot? I have check the front suspension and everything else seems to be fine. thanks
did you find out what the problem was, I have the same noise only in the rear Edited by cecollins
  • 7 years later...
