Help with Headlight Washer Cover
You can do it with a helper, on your own is difficult.
Pull the telescopic tube out with 2 flat screwdrivers, there is a strong resistance by a build in spring
Let the helper hold the telescopic tube as close as possible to the headlight while you remove the rest of the nozle
Push the new nozle/cover combination on the telescope
Thanks RFM,
Job done
Luis Redinha
