Use you (mechanical) key to lock the car. Then use your key to unlock the car. Then try to start it.
If that does not work... does the engine crank?
Hej Loren!
The engine does not make a sound.
All other functions work on the car.
Hej Loren!
Hallo! I called the dealer first thing Monday morning and we found the problem.
It was the transponder inside the keyhousing,glad it was as simple as that.
Regards Mika
