Hi Loren
Scratching my head to find the update CD for the PCM2.1 From Version 04202xxx Level B upwards
I have part number 000 043 205 47 002 as being discontinued. So I don't know if this is a USA number or for all markets - I am UK based.
Can find "000 043 205 47" but no ideal what this is
Already bought (but not yet delivered) the 05.2007 original (still sealed) Europe map DVD from fleabay.
Please help before I pull what little hair I have out lol
Thank you in anticipation
Lee
I see both 000 043 205 47 003 and 000 043 205 47 004 in the system but they have no description other than "cdrom".
You might check those part numbers with your local OPC.
Local OPC useless - they see the same as you & me :(
They only want me to buy the 955.044.90.260 map update at £340
Hi spoilednpimpin
Just mailed you.
Can't wait for some good news :D
Kind regards
Lee
can any one upload that pcm2.1 update cd level -B- with part number 000.043.205.47.002
is for Cayenne 2004
thanks for reply!!
regards John
Please do not ask members here to copy copyrighted material for you.
Please re-read the board Guidelines/Rules that you agreed to when you registered here.
"You agree not to post any copyrighted material unless the copyright is owned by you or by this bulletin board."
is for Cayenne 2004
thanks for reply!!
regards John
Yes i agree but the dealer do not sell me that disk. Say is services disk and not for sell.So for that i post it!:)
So if any one have that update disk pls send me pm!
Is important!i can purchase the original to!
Edited by snoopjohn
is for Cayenne 2004
thanks for reply!!
regards John
What part of breaking the rules here do you not understand?
You are asking someone to break the law.
DO NOT POST COPYRIGHTED MATERIAL HERE - OR ASK THAT IT BE POSTED HERE.
Hi Loren
Lee
From your post it sounds like you have an early PCM 2.1 , possibly pre 2006. The software level is level A at the moment so your PCM will be using a 2004 map DVD. You cannot use the 2005 or later Map until the PCM and navi drive has been updated. There are three CD's to do this task which cannot be bought sepatately from Porsche , they come as part of a "kit" supplied with a new Map DVD. The CD's you listed are for bose and telephone updates and will be of no use in your situation. I would advise against a self update unless you are fully familair with the update process , and certain of your current software level and hardware installed. If your car also has Bose there are some other pre requisites that need to be considered before updating , otherwise the Bose amplifier can become a brick and potentially the PCM too. Since you are UK based , I may be able to assist. Send me a personal message and we can discuss what is required for the update offline , as its somewhat complex and different for every car.
Email sent. :D
Email me at SLP01005@aol.com, I can help you with this.
