HELP
Porsche repair shop put in three switches and 7 weeksof working on car, problem not resolver Codes PSM 4340 Brake posistion Sensor & DME P1574 Stop Light Switch fault come up.
The system is cleaer on start up but alarms come up 1-10 min after driving.
HELP
Fault code 4340 Stop light switch
Possible cause of fault:
- Short circuit to ground/B+ or open circuit
- Wiring/plug connection faulty
- Mechanism of the stop light switch not OK
- Adjustment of the stop light switch not OK
- Pressure sensor plausibility
P1574 Stop Light Switch – Signal Implausible
Fault area:
Both stop light switches closed.
– Stop light switch
– Wiring harness
If they have replaced the switches then the problem is likely the wiring.
There are simple tests to determine the problem in the manuals. You will also need a special tool used to measure continuity to the DME and a volt/ohm meter.
Fault area:
– Stop light switch
– Wiring harness
Thanks Loren
I tried a experiment:
I removed the switch out of the socket and drove the car, The PSM Off and ABS lights came on.
I removed the wire from the switch out of the socket and drove the car, The PSM Off and ABS lights came on again.
The auto shop said they traced and checked all the wire back to the controllers, and the wires checked out OK.
Any other ideas besides a stick of TNT?????
John
  • 2 months later...
Loren
After 4 Months WE Found The Problem
WE checked the following:
Voltage while driving, OK
New battery
All new tail lights
3 new brake switches
Tested all the wire form the test sheets you sent me OK
The fix was:
At the CPU behind the seat we shielded th wires. Problem fixed
All fault codes are clear and fault ligt stay off
Loren, Any ideas why this problem came up to begin with.
