Hydraulic brake line to caliper (in need of one)
Wanted to get information regarding the metal hydraulic brake fluid line that goes into the side of the caliper. I stripped the threaded screw that holds the line securely into the caliper and wanted to know if there was a part number available to get a new one.
TIA
-Matt
Edited by ///MJFDDS
If you like cool stuff they make stainless steel fexible brake
hoses for 997's. Since you got the line loose there
is this option also.
Paul
Yeah, I thought about doing that, but figured I will just do the one replacement since I just re-insalled / bled everything after having my calipers re-finished. Thanks for the suggestion.
