04 Headlight Rubber Seals (surrounds)
Can you replace the rubber surround seals on the headlight units. Mine are looking ragged. Also the wedge seal between the light inboard and the body. Part numbers if they are available please loren
thanks Loren, no its not must be body mechanical, It seals the gap between the inboard side of the lights over the join between the fender metal and the front cross member top.
955.631.115.00 Left headlamp gasket -- MSRP $42.08
955.631.116.00 Right headlamp gasket -- MSRP $42.08
I'm not sure about the other part you are asking about - is it in the diagram?
