Quick Question - Is the K&N filter as good as BMC?
Hi guys,
It is time for me to replace the air filter on my '01 Boxster and I am considering adding a non-paper filter.
The guy I source some of my parts from no longer carries the BMC element since he said the K&N is as good as for a fraction of the price. $34 for the K&N, $90 for the BMC.
Are both filters equivalent?
On another note, any reason I should stick with the paper (OEM) filter - I like the induction noise and will let the oiled filter rest for a while wrapped in newspaper if I decide to go that route? Anything else that could go wrong with these?
Gus
Edited by gandrade1
Gus
A good number of folks have had problems with the oil fouling the MAF sensor. I use K&N on my old -6 with no problems.
Gus
Gus:
Ditto for me. The chance of fouling the MAF is not worth the sweeter sound of the intake with a K&N. The Boxster throws enough CEL's without adding another possible source.
Also, those new MAF's aren't cheap.
I understand that the later model MAF's are not as susceptible to fouling because they are a different design.
Regards, Maurice.
Gus:
Regards, Maurice.
So....no go for the K&N (or BMC) ?
How do I know if my MAF is one of these 'improved' ones? I have a 2001 2.7L Boxster.
Thanks, guys.
All the best,
Gus
Just came across these comments...K&N Claims
I will call them and ask if they replace my MAF if I get a CEL immediately after I install the filter...
:rolleyes:
In the video they have, it sounds like they'll take the failed MAF and do a full diagnostic and chemical analysis on it. They talk about having tested 107 MAF sensors so far, and give a breakdown of what they found. So, yeah, they MAY replace the MAF for you :)
Gus, as you mentioned, most of the problems that arise from a bad MAF are caused by improper oiling of the filter. I've had an Evo Hi-Flow on my '02 S for the last three years without problems. Yes, oil it and wrap it in newspaper (been doing this for years on my 911s). I don't know if the K&N breaths the same as the BMC, but I think either would be perfectly acceptable when used properly.
