Sunroof rattling when closed. Help!
My 2001 996 carrera 4 Tip coupe has a rattle from the sunroof when I go over bumps, the rattle stops when the sunroof is open (even very slightly open) is there any adjustment on the motor stop position for the roof, as I was hoping this could cure my rattle if it could be adjusted.
Any other suggestions on the cause of my rattle would be much appreciated.
Hi Loren, I searched through the 996 TSBs but did not find one pertaining to a new style deflector. Can you help? Thanks!
Have a look at the TSBs on the sunroof.
There is one for a new style deflector and another for various noises.
Have a look at these for your problem:
1/03 6028 Tilting/Sliding Roof Noises -- dated Mar 5, 2003
4/01 6040 Noises in the Sliding Roof -- dated Oct 12, 2001
5/01 6028 Noises from the New Style Sunroof Frame -- dated Oct 5, 2001
Thanks Loren, I saw those. I needed to buy a replacement air deflector as it is missing on mine. I ordered a used one, and then saw your post so I wanted to see which ones I got. But maybe I missed it in those TSBs, I don't see a change to defector, I guess it maybe consolidated as part of new frame.
thanks again for pointing out those TSBs!
