I left my car at a public parking lot 2day coz the key was stuck and i cant pull it out and the car as in the park position what should i do? i cant even turn the key its like it just froze is there anything we do about this? :o
Yes a few day ago my ignition was acting strange no ac the i have to jiggle the ignition the ac turn on read in the forums is the switch givng out?
Did you try relieving the pressure on the steering wheel - by turning slightly in each direction?
Could it be a dead battery?
From the owners manual:
Key Stuck in Ignition?
* Do not insert the ignition key into the ignition if the vehicle battery is discharged: the ignition key can no longer be removed.
* The key cannot be removed until the vehicle electrical system is supplied with power again.
Strange ADias, looks more something for 997/987 with electronic lock.
Hmm You learn something new everyday here!
