I'm working on upgrading my rear speakers and a photo DIY to be posted here. I've already installed one speaker but think the procedure would be much neater if I were to remove the interior panel and finish the speaker install with the panel out of the vehicle. Can't figure out how to removel the interior panels - can anyone help? Thank you!.
Sorry! 1999 C4 Coupe. Premium Sound. Want to get the rear quarter panel off so I can post the how to on installing Focal Polyglass 130 5 1/2 speakers. I've already done one side but want to improve the install for the other side.
1. Pull seat belt rose cover up and off.
2. Undo fastening screw behind it (be careful not to drop it into the chassis).
3. Detach side-panel lining by unscrewing the hex bolt for the rear seat latch. Pull locking lugs of side-panel lining out of the clips in the rear side section and move forward enough to get at the back of the speaker.
4. Disconnect the loudspeaker electrical plug connection and disconnect. Remove panel.
Loren - is the seatbelt "rose" the black plastic "U" shaped cover where the shoulder belt goes into the side panel?
