Getting High
Hi Guys,
Ok update and more help needed
I have been lent very kindly by a good chap, a diagnosics kit, I have read the following faults in the memory since giving it a good drive.
P0150 - O2 Sensor ahead of cat conv (cyl 4-6)
P0300 - Misfiring damanging to cat.
P0306 - Cyl 6 misfiring damaging to cat
P1119 - Heating power O2S ahead of cat. bank 2
I then analysied the misfire read outs, and cylinder 6 was misfiring quite heavily, while Cylinders 1 and 5 misfired once (over a period of around a 5 minute drive)
I then read the voltage of the O2 sensors over a 72 second period
On Bank 1, the lowest voltage was 0.07 and the highest was 0.82. The values were shooting up and down at every samples rate
On Bank 2, the lowest voltage was 0.13 and the highest was 0.24. The values stayed quite steady with every sample rate
What are your immediate thoughts??
Many thanks
Russ
Edited by RascalRuss
