Noise in rear suspension...
Hello all...
I've just installed 18X10 rear wheels with the correct offset.
Now,when I hit a dip in the road,I get a strange noise from the left rear.
It sounds like a cross between a clunk and a rub. Don't know how else to describe it!!!
I tried 5mm spacers but noise is still there. Doesn't happen on a sharp bump on the road,only
on a dip. I can't for the life of me see any signs of tire rub,but that's kind of what it sound like.
Car is a 2000 S.
Any suggestions?
Cheers
Mike
Hey Mike, I would remove the left rear wheel then inspect the inner rim(edge) to see if there is any rubbing mark,,,
Hello all...
Car is a 2000 S.
Any suggestions?
Cheers
Mike
Hello all...
Car is a 2000 S.
Any suggestions?
Cheers
Mike
Yup...I've already done that and it looks good. No sign of rubbing anywhere.
I had the car on a lift so I was able to have a good look.
This noise did not happen with the factory 18X9"s.
Thanks.
