I switched seats this weekend and when I went to drive it I had the airbag light on. Connected DUrametric and the Driver and Passenger said fault 49. I reset both but the passenger one keeps going on. Did I miss somethibg when I reinstalled the seats?
2000 996 Carrera
So is there a fix? It wasnt a problem before I removed and reinstalled..I just cleaned the car and put the seat back in. Pinched wire...bad receptacle, replug the harness? Thanks for any help.
You can try cleaning the buckle contacts (as described here elsewhere) and checking for pinched wires... or if that does not work then you need to replace the buckle.
