Steering Cover
Hi Guys,
It has been a while since I posted and want to start off by wishing you a Happy Holidays.
Anyway, I need some help or directions on how to remove my steering cover. It seems that the switch inside the cover is shorting and causing the horn to sound intermittently and it is getting worse. I would like to take the cover off and check what the problem is.
Also, does anyway have the fuse box layout diagram so that I can pull the fuse in order to trouble shoot?
Any help will be appreciated!
Do a search here on horn problems - chances are your problem is the steering wheel bushings.
Hi Loren,
I have done a search and did not find anything on how to remove the steering cover to check the bushings. Can I just pull it off gently?
Also, I could not find the fuse box diagram, is anyone willing to share this with me please.
Edited by flyboyshell
