I have an 04 CS, owned since brand new, this winter I am now having defrosting issues, the defroster is having trouble getting rid of the condensation within the car, is this a freon issue??? anyone know?
the defroster fan comes on full blast (lots of heat) yet it is having trouble dissipating the fog on the glass quickly. I know that some defrosters use the A/C to work quickly, that's why I wonder if it's a freon issue.
I know it's been a while since this thread started, but did you ever resolve the issue? I am having the same problem, especially when it rains. The intake area is dry, so not getting water into the fresh air intake, and the intake drain is clear. I suspect it may be the air quality sensor under the hood just inside the fresh air intake, which I believe measures intake air humidity to control the A/C. Thanks.
