p0308 number 8 cylinder misfire
Hi I'm new here. I just had the dealership replace the coils and now I my engine surges at low RPM's. I did the OBD and it said P0308. Anyone heard of bad coils right out of the dealership. I will take it back but we are on the road for Christmas and now I have to go back. I was looking to see if the TSB thing has step by step instructions, because I wanted to check it for a crack or bad plug. So my next question is how do I get to look at the TSB things.
Joel
  • 3 months later...
I am having the same problem on my boss's '04 Turbo. Got this code when i tryed to read the fault memory:
Address 01: Engine
Control Module Part Number: 8TE 4AS N30 000
Component and/or Version: 0041850144FI8TE4G 30046
Software Coding: 0001133
Work Shop Code: WSC 128452
1 Fault Found:
16742 - Ignition Control Circuit for Cylinder 8: Malfunction
P0358 - 004 - No Signal/Communication
Readiness: 0110 1101
