Thinking of getting a 2001 Carrera. Any major issues?
Hi. 'thinking of getting a tiptronic 2000-2002 911 Carrera or Carrera 4. I've owned VWs, Audi, and a BMW 3 series before and done all the work myself on them in my garage. I *plan* to do the same to the Porsche. I see a lot of DIYs here and things look do-able. Are there any major problems with these cars (e.g. tiptronic)? Any help is appreciated.
Google 996 and IMS.
I wouldn't be overly concerned -- but I would make myself well educated so that I knew
what I was getting involved with.
They also occasionally have water pump problems.
m
Google 996 and IMS.
m
I see. Thx. Yeah the IMS/RMS failure looks pretty scary. I think water pump issues happen with every car, but that seems relatively easy to change out.
When you find a 996 that you really like, it is essential to get a PPI, including leakdown and compression tests. Ask the owner for Porsche records, the RMS may have already been replaced. Check CarFax for what it's worth. The IMS failure is a possibility but can be repaired efficiently I think. What really scares me are the many others who have had catastrophic engine failures, requiring replacement engines. A good extended warranty can help with the expense. There is nothing like a 911 so we accept the reality that they are expensive to maintain and repair, but as the advert goes, 'seeing your 911 in the garage... priceless!
Best regards,
Alex
