Hi All,
I've searched quite a bit and can't find a direct answer. I apologize if my question has been duplicated in the past. I've had two dead battery situations after my '02 base 986 sits for about 48 hours. Current battery is 1.5 months old. Since I've purchased the car in early November 2008, I've left the car in my locked garage with the key in the ignition.
Should leaving the key in the ignition create a large draw on the electrical system? If I leave the key in the ignition, I'm noticing a huge 2 amp draw on the battery. If I remove the key, I'm seeing a .03 to .02 amp draw.
Thanks for any help!
Jay
02 986
