can anyone post a a list of specific fuse locations for the drivers side box?
how do you remove that panel to get access?
i am having an issue with my indicator light ("check indicator warning") and my right signal flashes rapidly
funny thing is the indicator will start working again when i turn the car off/on again. i replaced the bulb and that didn't fix the issue. i figure i should replace the fuse.
this issue started happening after i installed aftermarket xenon fogs. i do not know how the indicator warning could be related to the fogs. i want to check all possible issues before i take it to the dealership as they might void warranty / blame it on fogs and charge me lots of $$.
thanks
matt
Cayenne's have 3 main fuse boxes, i highly recommend buying or download a manual, there are numerous of fuses and relays, you almost need a PDF file. The indicator issue is rather a bad contact bulb/bulb holder - bulb holder/headlight unit or connector.
i found fuses in the manual. thx
its not the bulb because i replaced it
i doubt it is the bulb holder because i swapped it to other side and the issue persists on the original side.
i am going to try some bulb grease
quick update
fuse is all good & bulb is brand new. i also added some di-electric grease at connection points.
i have no clue what is going on here and the error message is making me go mad....
i unplugged the fog light fuse to make sure the issues were not related and the error persists
any ideas?
thanks
if i take the car into the dealership for warranty i will likely have to replace OEM fogs so they don't void my electrical warranty?
