Can I adjust clutch cable by myself?
I got my car little over two years ago with only 2000 miles. When I first got it I've noticed the clutch engagement point is kinda high and I've just assumed that is how is it. Since the car only had 2000 miles and all. But I had the chance to drive other person's 996 and his clutch engages at around mid point. Is this something I can adjust or do I have to take it to the dealership to get it adjust?
The clutch on the 996 is hydraulic which means it operates just like the brakes on fluid displacement. So, the first thing I would suggest is having the clutch bled. If that does not fix it then there is a small amount of adjustment in the clutch push rod but I don't think as much as you describe. Also, there were some TSBs for some of the early cars (MY99-01) for pedal modification and new clutch springs so that could be part of it also. Have a dealer check your cars service history and see if any of the clutch TSBs have been performed.
