Fit TT wheels on 99 C2
TT wheels will not fit a narrow body car because of the offset.
Late model GT3 wheels (same width) will fit a narrow body car (brcause they have the correct offset). Now with that said - putting wider wheels on the car without changing the front wheel width also will give you quite a bit more understeer - in a car that already has quite a bit.
If you are considering 11' rear wheels then consider at least an 8" front and better yet an 8.5" wheel with a 235 or 245 width tire (the 245s may rub a little in tight turns). The car will handle much more predictably (IMHO).
