Loren, any chance you can look up my specific caliper/rotor size. I am ordering parts online to do a brake job and there are a lot of different sizes for the cayenne. I just want to make sure i order the right ones.
I have a 2005 Cayenne Turbo (no power kit)
VIN WP1AC29P25LA92692
Thx
MT
Front rotors:
955.351.401.51 Left front rotor 18" -- US MSRP $161.73
955.351.402.51 Right front rotor 18" -- US MSRP $161.73
You will also need: N.906.854.03 hex-head bolt (2 each)
Front Pads:
955.351.939.14 Pad set -- US MSRP $203.62
Rear rotors:
955.352.401.31 Rear rotor -- US MSRP $122.17 (each)
You will also need: N.105.556.02 hex-head bolt (2 each)
Rear Pads:
955.352.939.02 Pad set -- US MSRP $143.10
Front rotors:
Front Pads:
Rear rotors:
Rear Pads:
thanks for the speedy reply loren
any idea on the size 350 or 330mm for front rotors and rear
i am ordering aftermarket pads and rotors so the Porsche part numbers are not applicable
thanks again
mt
did a quick search:
"You must determine the size of the rotors on your vehicle prior to ordering. The easiest way to figure out your brake size is to look at the caliper. It should have "17ZR" or "18ZR" cast into the body. 17ZR=330mm (black caliper), 18ZR=350mm (silver and red caliper). In general the V6 has the 330mm rotors and the V8 has the 350mm rotors."
i will check my brakes tonight. but assume they are 350mm up front
need to confirm rear
