i have noticed that the coolant level in the reservoir is below the min line but there is no warning light on the dash
is this a problem?
i noticed while checking what sounds like a fan belt squeal on my 2003 996 that i bought 1 week ago
i assume that i just need to top up and monitor the level (i have seen some other postings that could suggest bigger problems so I hope that this will solve the problem)
can someone please recommend a compatible coolant for a 996
:welcome:
Please do a search coolant has been covered many many many times here.
You can check to see if your coolant light is functioning by just turning the key to the on position - all the warning lights should light up.
i blieve the proper coolant is pentosin
is this a problem?
is this a problem?
Porsche's coolant is made by Elf.
