I hope someone can help me out with four questions that I have about 2001 986 S wiring.
1. Can someone confirm that the fuel gauge sending unit is sending an ANALOG not Digital signal?
(I don't have access to an oscilloscope)
2. Where would be the best place to tap onto the fuel gauge sending unit wire? (My first guess is behind
the gauge cluster but have not traced out which pin or wire color yet) anyone have a better location?
3. I would like to tap onto the reverse light wire (backup lights) with out going back to the transmission
reverse switch if possible to get an energized siganal when the back up lights come on. Anyone know
of a better location under the dash? (wire location and wire color?)
4. I need to tap onto the Speed sensor line. I know some people have used Pin 18 on the cabrio relay to
send speed sensor info to Becker Radios that are not getting sensor signals to activate GAL settings
Any better locations for doing this? Would behind the gauge cluster be a better place? pin and color?
Thanks in advance for any help,
Can you tell us what you are trying to connect? Shift computer? Lap timer?
Hello Loren, Thanks for the reply and that is a good question. I was looking for a way to have the chrono option in a 986 (see photo) I found a Coralba C-rally computer that had two clocks that worked at the same time (each can be set to count up or down). Any way I also got some features that I really did not need, but rather than have three wire leads wrapped up behind the unit I thought I would see if I could hook them up also. The anolog fuel wire, the speed sensor wire (for speed and distance) and the back up light wire (which will make the trip meters run backwards when the car is in reverse) Like I said I really don't need these features. If some one is interested I have photos and could write an article, or at least if I get it hooked up I can let the passenge play with it while I drive. The two red switches (left/power & right/ resets any computer function that is presently displayed. Thanks for any help...
1. I do not know - you will need to test it.
2. The Violet wire coming from the instrument cluster B4 (Blue plug) is the fuel sensor.
3. Use the reverse connection under the drivers seat. See the TSB on the Traffic Pro install for details.
4. Gray Pink wire (several to choose from). Try to pick one that is not already in use.
Thank you very much, especially the connection under drivers seat info, also I uninstalled the DPS a few years ago, so that connection is right behind the unit and empty now. You really saved me some time! Make it a great day!
