Map light interior light fuse?
Hey guys, I was going to swap out my overhead dome map light bulb to a 194 LED bulb, and seem to have shorted it out, since it no longer turns on. I went to look for the fuse in the fusebox area by the footwell, but was unable to locate the fuse for that center maplight.
I've done a few searches, but have not been able to find the answer. Perhaps I am overlooking the obvious somehow in that fusebox area, but if anyone knows the answer, that would help me out tons.
Thanks in advance!
Edited by chaudanova
Try C3 - that is labeled inside lights.
Great, you're right Loren! I overlooked it since it was bundled with a few other things as well. Turns out my fuse was fine, it was just the connector on the lighting clip that was a bit loose and needed to be jiggled into it's proper fit.
Thanks again!
:renntech:
