How do you remove the center console with a Tiptronic?
hi. On a 2000 C2, with Tiptronic tranny, i wanna remove the center console (where the E brake and ashtray is). in all the DIYs I see, you have to remove a screw below the stick shift, so you have to remove the stick shift assembly. But how does one do that with a Tip?
I recently removed the center console on my Carrera C4S with tiptronic. You need to take the shifter knob thumb button used to shift gear, it pops off. You will see a clamp around the shaft of the shifter, use a flat head screwdriver to pop it off, once you do that you can pull the shifter knob off. After that, you carefully lift the center console out.
