Hi, I have cayenne S 04.Does anyone know where is the problem with P0907 fault code.
thx
Fault code 0907 Load management operation on vehicle electrical system/DME control module
Possible causes of fault:
- 'no display' Loads are/were switched off temporarily. The load management operation was enabled because of undervoltage.
Most common cause of this is a bad battery.
Some Cayennes are fitted with two batteries, main battery under left seat and starting battery located in spare wheel area. Be sure to test both batteries.
