:welcome:
659 should be a 3.0 liter 1979 engine as used in that year's 911 SC.
Cool thanks! Where can I look to find similar numbers to identify the transmission? The previous owner said it was a G50.
If it is on the same car it should be 915.61 5 speed and the transmission number should start with 719.
I don't think G50 started until 1987 so if it has a G50 someone upgraded. In that case the transmission number would start with G50, or 73H, or 74H.
