replacing light switch soon, does battery need to be discon...
disconnected? found diy here but does not mention main battery disconnect. probably a good idea, eh?
It's always a good idea to disconnect the battery when doing electrical work on the car. Just take the key out of the ignition and disconnect the negative battery cable, at the battery.
Make sure that if your radio requires a security code, that you have that before proceeding.
Your DME will have to "relearn" its parameters once you reconnect the battery but that's an automatic process.
Regards, Maurice.
