My model is a Cayenne S ,MY 2005. The problem that my dealer has no answer and cannot fix, is that when I turn on headlights, a message appears as a warning "Check head light beam adjustment" and a yellow ! appears. This warning comes off, and from menu also, (vehicle info, warnings) after ignition off, and lights up again during next ignition on and headlight on. Lights keep working normal, but during driving this message is coming on again as a warning. My dealer cannot find where the problem is coming from, and has not any answer at all. Any help would be precious. Thank you in advance. My address Thessaloniki, Greece.
I have a similar issue with MY 2008. The problem started intermittent and now remains every time I turn the vehicle on. My error is "Check Headlight High Beam" and a yellow ! appears. My dealer told me a TSB was released that told them if the could not reset the error, they would have to replace a control module. Thus, I am waiting for a control module. I have been waiting over three weeks for a control module (9551012702) to arrive at my dealer so they can make the repair. My frustration is the fact Porsche cannot tell me when the part will be available. I know they run SAP and with that ERP system, the dealer must have visibility into lead times and first acknowledgments for dock dates...anyway, that's where I'm at with this issue.
First issue I've had with our "08...little frustrating I cannot get a part.
All the best,
Bill :beer:
I had the same problem, it turned out to be a sensor on the rear suspension (controls headlight level at speed) OPC had the car for 4 days before they fixed it mind!
Cayenne MY <06 are differend than MY >08 regarding light control and many more.
