I knew that this may be a stupid question.
Anyone know how to display a Degree Celsius ( Instead of F. )temperature reading?
The manual doesn't provide any information.
thanks,
On the cluster? If so, see your owners manual.
or on the climate control display?
On the Cluster. But my steering column doesn't have the " Operating lever for OB Computer ". The owner manual refers to the change with that function only.
I can change the Climate display by press both Recycle air and the + button, but no lucj for the cluster.
thanks,
Outside temperature is a function of the OBC - which is present whether you have the stalk or not.
In MY99 there was a separate cluster for Canadian cars that displayed temperatures in degrees C.
