Does anyone have torque values for the TPMS valve stem and sender in the wheel? There is the external nut on the valve stem and the small Torx head screw that attached the sender to the valve stem.
Thanks in advance for your input.
Edited by DUTCH VanAtlanta
Both the nut and Torx screw are 3 ftlb. (which is not very much).
Thanks Loren. I would have thought the larger nut on the valve stem would have been greater than that; but it does have air pressure holding in place from inside.
