Help - Set Up H&r Coil Over Suspension
Can anyone help me with ways to adjust the height of my 993 cabrio?
The former owner installed th eH&R coil overs and set up the height. The rear seems OK, but I find the front like 0.5 inches lower than the rear. My understanding if that these two have to be equal?
I have 225/40/18 front and 285/30/18 rears on Pirelli Rosso's.
I know how to raise or lower the suspension, but don't know if they need to be equal or what. Also, what height is best, assuming street driving.
Orc
Ride height adjustment will effect attainable maximum camber and corner weighting.
If you are not tracking the car then corner weighting is not very important so you can set the ride height to whatever you want. Now it comes down to a matter of appearance and ground clearance. You set the ride height to however you want the car to look and as long as you are not bottoming out all over the place then you should be okay.
If you do change the ride height then you will effect the alignment. Get the car realigned at a competant shop. You may want to discuss how you intend to drive the car with the shop to see if they have any suggestions as to what the alignment should be.
