Error Codes P1249 P2111 P1828 P1255 P2101 !
:huh:
Just had a leaking gearbox fixed and engine loom repaired and now I get these error messages! I swear the car is costing me an arm and a leg.
Has anyone experienced any of these codes and found the cause:
P1249 Boost Pressure Control
P2111 Throttle Actuator Control System stuck open
P1828 Pressure Control Valve
P1255 Boost Pressure Curve, Upper value exceeded
P2101 Throttle actuator control motor circuit range/performance
00801 High Press. Switch coupling.
I have already done a search and the brilliant Loren came up with
P1255 Boost Pressure Characteristic, Upper Value Exceeded - Above Limit
Possible fault cause
- Leakage at pressure hoses from frequency valve to the bypass flaps
- Frequency valve faulty
- Vacuum modulators for bypass flaps leaking
- Bypass flaps incorrectly adjusted
But what about the others? I have been told a single fault can create multiple error messages.
Strange thing is that when I drive no PCM ABS lights come on. The light only comes on at 90 mph with my foot down.
When I stop the car turn off ignition and restart the car the lights go out and everything is fine. Foot down upto 70-90+ mph not a problem.
Any advice greatfully appreciated. Everyone speaks so highly of a 996 turbo but this one is proving to be a bit of a ball ache :huh:
Cheers
:renntech:
Edited by Vorland
Sounds like things were not put back right.
I would take it back and tell them you did not have these problems before their repair.
I would but I dont trust him anymore. He was a nightmare to deal with. :angry:
Seeing these errors do you think there is multiple problems???
I was told that a single problem can cause these error messages?
Edited by Vorland
hi, you may check the connector from the tiptronic transm (lifting the car).
it has connection to the e-gas , ecu ....... :)
also leak in the turbo charging sistem could cause these strange problems. you could check your boost on third gear with 3000 rpm ---> ;)
good luck
911rs
