After finding my tires almost flat (possibly due to a prank, i.e., no nails, no leaks), I decided to purchase a tire pressure monitoring retrofit system from Hella (model TC-400, from tirerack) for my 2002 996.
I had originally intended to install it behind the center console, but the instructions recommend against it.
I was wondering whether anyone has recommendations for alternative locations for the receiver, what wire I should tap for power, switched power and ground (are there spare locations in the fuse box?), and what a good location is for the display (glove box?)
I have an aftermarket, and thinking of velcroing mine on the left side of the dash just to the right on the drivers vent. Then you can tap in with an add a fuse just below in the fuse box
