1998 996 Air con again still not cold enough
Just wanted to know if you push the switch for the compressor to come on does it make any sound or does the engine note change at all as if a small load is being applied due to the compressor switching in..
I have topped up my Air con system to 30psi with the gas and its still not getting cold, just wondered if the compressor was switching in.. does anyone know what the required system presure is, also wanted to test the presure switch.. Any help would be appreciated..thanks
What kind of refrigerant are you using?
The engine idol on my 996 goes up by a couple hundred rpm when the compressor kicks on. My car took about 6lbs of 134a refrigerant to recharge. This seemed like a significant amount considering the size of the system. The low pressure switch closed at about 5 lbs12oz
