Shifting from N to D while driving?
I've never had any problems doing this on my Porsche (1999) or other vehicles. The transmission simply selects the right matching gear as you shift from N to D. The real problem is doing is smoothly and also making sure you don't accidentally get it in R.
Haha, definitely not because of the Toyota thing :D
Just want to be able to rev the engine while moving, the reason I am nervous about doing it is that there is a small warning in front of the gear lever that says you shouldn't move the gear lever without holding the brake pedal down.
...there is a small warning in front of the gear lever that says you shouldn't move the gear lever without holding the brake pedal down.
That may mean you can't go back from N to D without stopping.
