PSM problem...help
Hello there guys...I am experiencing some troubles with PSM...It flashes and code is 4206,front left speed sensor...I replaced it but the code is still there from time to time...any ideas?First sensor was "short circuited to ground" while second sensor was signal implausible...Is there a polarity to sensor connector?The car might run ok for 200miles and then suddenly PSM/ABS is on...Help please...
