Monitor the fuel trim but there is no actual value that states "Rich" or "Lean" like some domestic scan tools display.
I do not see any fuel trim logging for the durametric?
The adaptation values can be read out with the Porsche System Tester 2 and I suspect Durametric can read the same.
The key to the adaptation values is as follows:
RKAT = Adaptation in range close to idle - Cylinders 1 - 3
RKAT2 = Adaptation in range close to idle - Cylinders 4 - 6
FRAU = Adaptation in lower load range - Cylinders 1 - 3
FRAU2 = Adaptation in lower load range - Cylinders 4 - 6
FRAO = Adaptation in upper load range - Cylinders 1 - 3
FRAO2 = Adaptation in upper load range - Cylinders 4 - 6
FR = Oxygen sensor - cylinders 1 - 3
FR2 = Oxygen sensor - cylinders 4 - 6
The Porsche PST2 can display the following actual values and I think the Durametric can too:
Actual Values
Values present at the moment of the test can be read out with this menu item.
The following values can be called up:
- Engine rpm
- Load signal
- Air mass
- Mass air flow sensor
- Vehicle speed
- Voltage
- Intake air temperature
- Engine temperature
- Throttle valve angle
- Ignition angle
- Spec. air mass
- Spec. air adaptation
- Ambient pressure
- Injection time
- Exhaust temperature after TWC (three-way catalytic converter) (value calculated by ECM)
- Oil temperature
- Oxygen sensing, cylinders 1 - 3
- Oxygen sensing, cylinders 4 - 6
- Adaptation value, area 2, cylinders 1 - 3 (FRA)
- Adaptation value, area 2, cylinders 4 - 6 (FRA2)
- Adaptation value, area I, cylinders 1 - 3 (TRA)
- Adaptation value, area I, cylinders 4 - 6 (TRA2)
- Voltage, oxygen sensor ahead of TWC, cylinders 1 - 3
- Voltage, oxygen sensor 2 ahead of TWC, cylinders 4 - 6
- Voltage, oxygen sensor after TWC, cylinders 1 - 3
- Voltage, oxygen sensor 2 after TWC, cylinders 4 - 6
- Trip counter
- Time counter after engine start-up
- Camshaft position 1 deviation (cylinders 1 - 3)
- Camshaft position 2 deviation (cylinde rs 4 - 6)
- Rough running threshold value
- Rough running
- Segment A
- Segment B
- Learning progress of sensor wheel adaptation
- Misfire detection
- Engine compartment temperature
- Oxygen sensor heating resistance after TWC
- Oxygen sensor heating resistance ahead of TWC
I believe you are right on the durametric readings, but was concerned with:
What do they represent?
I am concerned about the ones that could give me a indication of AFR and would think that the O2 reading voltage would be one of them in the calculation.
