Oil Pan Baffel 3.4 ltr
I have an X51 oil baffle in my '04 986S 3.2L track car. http://www.suncoastparts.com/product//x51panAA.html
It is a straight change out.
Flat6 has a kit that changes the existing baffle, extends the pick ups. It makes sense, but involves some more work. I think Mantis has somehting similar too.
But I wonder if your issue is an overwhelmed AOS? If you are getting the smoke when you are standing on the throttle on exit, especially on left handers, that's classic AOS issue for the track. In my '04, I was able to fit a Porsche Motorsports AOS without modification. Not sure about 3.4 or the year of your 3.4. The AOS mounts differently on older cars - the mounts are on the side - with the newer version (and the motorsports version) it mounts through the base. I changed out to the motorsports version a few years ago, and haven't had any smoking since then.
