I have never seen this topic on the forum. When I take off hard from a dead stop it feels like the left rear suspension moves like it is slightly behind the right. It does not feel like the axel or differential and never happens when I take off "normally". There is a slight clunk like something is loose. It is NOT the cardan/drive shaft. I replaced that already. Any thoughts?
Check the rear control arm bolts. Sometimes they don't get tightened correctly after a wheel alignment.
Ok, checked the rear and as many links, bushings and bolts as I could see. I went for another drive, hit the throttle hard from a dead stop and now I swear it could be the drive shaft. Since I had this replaced last year at the dealer, I will bring it back to them for an inspection. Could this happen twice?
I went to the dealer Saturday (1 1/2 hours away!). I have interesting results. They said that the drive shaft had some play in it and they would replace it (under warranty). This supports when to use the dealership, I decided a year and 1/2 ago to have the dealer replace the shaft. They charged $650 for the shaft and 2 hours labor at $105/hr. I figured if I bought the shaft at the same price it would have taken me considerably longer to do the job AND they warrantied the part for 2 years and the labor was lifetime.
The downside, I still have the same clunk. The service tech said other than normal wear (at 92,000 miles) the suspension and mounts were all good. I definately have some sort of movement going on in the rear suspension. They said it could be inside the differential but I have no whine or any noises. If I ease into the throttle there is no clunk, if I throttle somewhat hard from a dead stop you hear it. If I am going 30mph and hit it so it goes into 2nd you can feel it. Something is twisting and hitting the under carriage but I can figure out what it is.
Do I take it to another dealer or is there something I can check?
Nothing loose inside the trunk, under the carpet, tools, control boxes or similar objects ? It's just an idea.
No, nothing. There is nothing loose in trunk. It is definately something in the drive line or suspension when you give it any type of hard acceleration.
The most common issue, which made a clunk noise and hit the under tray, is the main drive shaft bearing. Curious for the outcome.
