i have searched and come up with nothing i thought it was simple thing to do on the digi display i am sure twiddleed one of the knobs on my 996 and it did it so how on my 997 please
Very easy to do...You just use the stalk on the left and cycle through to set and then up and down to the desired function. Piece of cake!
DC
thanks a lot i knew it was simple and dont have manual hence the question :)
This should help you..You access these from the lower left stalk. Good luck
DC
