04 Cayenne V6 -- Timing Advanced Fault Code
Any help on this would be greatly appreciated. Cayenne now idling very irratic, fault codes for "Timing Advanced" and misfires in 3 cylinders.
Any idea's what the cause may be ? Would a bad oil pressure sensor cause this. Car was running great, came on during a long highway trip.
Replace the ignition coils and spark plugs at the same time. Also be sure the rubber seal for the engine bay is in place near the fire wall area. Water can leak down onto the engine and get into the spark plug tubes which shortens the service life of the coils.
