Hi can i get some info on whats wrong with my car. i have 3 warning lights on (pgm off,abs,and the brake pad indicator beside it) will appreciate the help guys. thanks
Hi loren the switch seems to be working fine, or is there any other way that it may be a problem? appreciate your input on this. just worried about travelling today. thanks
Check for any fault codes with an OBD II reader. Check the connection on the MAF.
Any off road excursions or recent damage?
Any mechanical work done lately?
nope no mech and no major travel. its just mostly around the city. engine is running perfectly normal. no peculiar changes on the driving. coonection on the maf can cause that? even if engine is running normal? thanks
