A friend's boxster (2002 base model in California) produced 4 codes after not starting:
P0134
P0446
P1130
P1128
It looks like the first one is for the No 1 bank O2 sensor before the cat
The second one might be a loose gas cap - could it be something else?
The other two I can't locate with the search. Any ideas?
Thanks for the help.
david
P0134 Oxygen Sensor Ahead of TWC, Bank 1 – Interruption of Signal
Possible causes:
– Wiring harness
– Oxygen sensor
– DME control module
P0446 EVAP Canister Shutoff Valve (Function) – Below Limit
Possible causes:
– Purge air line blocked
– Flow resistance of EVAP canister too high
P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Below Limit
P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Below Limit
Possible causes:
– Incorrect signal from MAF sensor
– Fuel pressure too high
– Fuel injector leaking
– EVAP canister purge valve open
