One of the headlight courtesy light specifically the passenger side is not ON, I check the bulb and is okay. Before this light was ON and Off between starting the engine On and OFF now is permanent OFF.
What can be the problem.
Check the bulb socket and then check the socket in the fender where the headlight plugs in. The inner fender socket can be broken easily by someone slamming the headlight into place and/ or the pins in the socket occasionally get pushed out and do not make good contact then.
I'll let you know.
B)
